WesR
- Phoenix, AZ, USA
I'm visiting one of my company's facilities for a turnaround; they've disassembled a boiler and are using a fan at the opening of the boiler to cool it down. The fan is plugged into a NEMA 4 receptacle, which is designated for use in Class 1 Division 2 Groups B, C, and D. The receptacle has this rating because the area is Class 1 Division 2. The fan has a general purpose cord, connected to a general purpose extension cord, connected to a 1 foot long cord that fits into the NEMA 4 receptacle. The portion of the 1 foot cord that plugs into the receptacle utilizes a twist lock system, and the other end is an ordinary plug; hence the connection to the general purpose extension cord. I don't think what they've done is permitted (to code), but the plant personnel said there is an exception in the NEC which allows the installation because it is temporary. I recall there being an exception for temporary installations, however not one that applied to Article 500, and upon inspection of 500, I saw no such exception. Some Questions:
Is there an exception for temporary installations in hazardous locations? - Where is it?
Where is the exception for general installations, or are there several exceptions in different places? - Are there actually no exceptions?
Since they're doing maintenance on a potential source that is a C1D2 location under normal conditions, is the area C1D1 while under maintenance?
Given the information provided, is the installation acceptable? If not, why not?
Thank you
Thank you
