Hello,
Some background...We have used 150 kw generators to power RV's (recreational vehicles) for about a 3 week rally period.....120/208 4w 3 phase 400 amps from the generator to a 400 amp panel (400-3P amp main, (3) 200A-3P breakers). Each 200A-3P feeds a 200 amp panel with (6) 30A-3P breakers. Each 30A-3P feeds a 10/5 SOOW cord with twist lock connectors (either 30', 60', 90' or 120') and terminates with a twist lock on a small pedestal with (3) 30A-1P breakers and (3) 120V 30A RV receptacles. The average current is about 16 to 23 amps each receptacle. The main load is the air conditioner.
Question...The 30A-1P breakers never trip, but when the day gets hot, the 200 amp panel gets a lot of sun, the buss heats from the inside and a 30A-3P breaker will occasionally trip cutting off (3) RV's. Does the code allow me to change the 30A-3P to a higher value? Again the main load is air conditioning and each RV has a load center or its own.
Many thanks for your help.
