Temporary power for outside use
dneveaux
I am building a panel for outside use and am wondering if I can use 4/4 so cable coming from it or do I need to use #4 individual wires? I am planning on using mini-cam connectors to tie in extensions from the service panel.
Check with your local electrical inspector. Some here in Minnesota will not allow 4/4 cable unless it is in conduit the entire way with a ground wire.
They are actually allowing SO cord exposed.
