JFletcher
- Williamsburg, VA
Forgive me if this is the improper section of the forum to pose these questions, but I was curious about temporary power (receptacles) and lighting in new commercial construction.
I do primarily commercial communications cabling, and I'm not familiar with the electrical side. Here are my questions:
1) Are new commercial buildings required by code (either building, NEC, or OSHA regulations) to have either temporary lighting or receptacles installed?
2) If so, is there any distance limit from the building that a receptacle "work station" (box with built in breakers and outlets) can be installed? What parts of the building have to be illuminated or powered, and at what stage of construction must/should they be in by?
3) Is there any requirement for number of temporary receptacles available per jobsite?
I'm not looking to install any temporary electrical circuits or anything, just curious to know what is standard or allowed. I've seen sites ranging from zero power (had to buy a generator, couldn't work after dark), two duplex outlets 125' from the building entrance (400' of extension cord needed to reach all areas), to two "work stations" (8 outlets each) per floor and lights every 12 or so feet.
