jdping2
- Monterey ca
I am providing a temporary power service for construction power to a jobsite in Redwood City Ca. Project consists of two 6 story residential buildings.
The owner had someone do calc's and have made arrangements for the utility co to provide service to a 800 amp 277/480 volt switchboard, whichI will be installing. The project has 2 man lifts each of which draw 92 amps and are 480 volt , so I plan to install 2-125 amp 3 pole breakers in the switchboard, one for each man lift. Also, the construction office trailers will require a 200 amp 120/208 pnel, I plan to install 1-100 amp 3 pole breaker in the switchboard and then feed a 45kva transformer , then the 200 amp 120/208 panel.
The remaining main switchboard capacity will need to feed each of the 2 buildings, under a separate contract. Question is, what is the largest sized 3 pole breaker ( we will need 2 of them, one for each building) that we can install in the main switchboard ? Can i install 2 -400 amp 3 pole breakers? If so, what would be the maximum load that each one of the 400 amp breakers could hold?
