I need to run temporary lights within a temporary walkway shelter. It is to shield from construction work above. It is made out of metal, so I need to ground it. The feeder to it will be done through an aerial overhead connection. My question is do I just tap off the Equipment grounding conductor and bond to the metal of the shelter, or do I need to treat the shelter like structural steel 250.104(D) where I need to bond it to either the Service equipment enclosure, grounded conductor at the service, disconnecting means for buildings or structures supplied by a feeder or branch circuit, grounding electrode conductor (if so sufficiently size), one or more grounding electrodes used, if the grounding electrode conductor or bonding jumper to the grounding electrode is of sufficient size? (I am hoping its not the latter since none of the options are anywhere near the temporary shelter)
