wireman1
can you mount blocks in a juction box for all your neturals and grounds which is seperate from the main panel?example above a 200  amp panel you mount a 12x 12 6 in. juction box mount a netural and a gronding block.from the service panel the  run the proper size pipeto the juction box.in the juction box you bring in your different feeds from the branch ciruits .all feeds are mc cable number 12 wire.connect the grounds and neturals to the proper blocks.the terminal blocks are fed with anumber 6 wire from the service panel run the hot wires from the circuit breakers and wire nut them to the branch ciruits .purpose is for deratingthe wires in the conduit .since there would be no neturals to count you could more hot conductors.i have heard of this being done is it ok by the code?ques. is there any time when the netural does not have to be counted as a current carring conductor such as in a 3 wire circuit
