vtsoundman
- NorCal
Working on a project relocating some service panels but need to leave the old panels in place (gutting the bars and using them as a j-box). What is the best way to avoid a giant CF of wirenuts in the old panel? (now a j-box after removing the buswork).
It would seem that a DIN rail connector and/or touch safe terminal block would be a much cleaner way to handle it.
I spec and use DIN rails and terminal blocks all day long for use in electrical control panels, etc...so specing the right 1492 DIN connector (allan bradley) or barrier strip is a non-issue.
UL has recently modified/altered/added complexity regarding Listed, Recognized components...and some of the DIN connectors & barrier strips fall into this category.
Use a terminal block or wirenuts to avoid AHJ issues?
