Terminal Connections Temperature Rating
Yes, you may find some 60° C terminals but in 2024 they are becoming more rare. Also it should be noted that the equipment that the terminal is connected to will typically not be greater than 75° C so even if you found a 90° terminal you would still be limited to the 75° C ampacity by the equipment itself.
