G gregory Senior Member Jun 12, 2006 #1 what is the terminal housing of a recessed luminaire? Does the code allow a person to run 3/8 flexible metal conduit from a junction box supplying the lighting circuit to the feed through box on a recessed incandescent light fixture?
hockeyoligist2 Senior Member Location close to greenville sc Jun 12, 2006 #2 look at this http://www.mikeholt.com/onlinetraining/special/codetip2005.php
Shockedby277v Senior Member Location Michigan Jun 12, 2006 #3 Check 348.20 (A) (5) which takes you to 410.77(C) . This is out of the 2002. Also 348.20 (A) (2) (c) again sends you to 410.67(C) Last edited: Jun 12, 2006
hockeyoligist2 Senior Member Location close to greenville sc Jun 12, 2006 #4 Shockedby277v said: Check 348.20 (A) (5) which takes you to 410.77(C) . This is out of the 2002. Also 348.20 (A) (2) (c) again sends you to 410.67(C) Click to expand... Just looked it up in 2005 its the same
G gregory Senior Member Jun 12, 2006 #5 fastest reply fastest reply Thanks for the replies, I can't believe how fast you replied. Thanks again.
