Terminations on 150A Breaker
kingpb
SE USA as far as you can go
Engineer, Registered
A strange request as been brought up, but not sure if it's doable.
Is it possible to terminate copper conductors on a 150A breaker that is designed for screw compression terminations of cable? I don't think I've seen a breaker designed specifically for termination of cable by say a one hole compression lug; which doesn't necessarily sound impossible just out of the ordinary.
Thoughts?
qcroanoke
Sometimes I don't know if I'm the boxer or the bag
Roanoke, VA.
Sorta retired........
Thoughts?
Are you asking if you can remove the mechanical lug and replace it with a compression lug?
I have seen them like that and some even list the compression lug part number to use.
qcroanoke
Roanoke, VA.
