Designer69
tesla has a standard 240V adapter/cable that they say to use a 50A breaker with, draws 38 Amps.
then they have the wall connector, also at 240V which can use a 60A breaker and draws 48 Amps.
how do they control the amp draw between the two methods? Some sort of resistor in the circuit that is bypassed when the wall connector is used? (they charge $500 for the wall connector)
