Test bypass for meter main ?
titan1021
I am looking at a job where I will need to add an additional meter main. I am not sure whether the new meter main will need to have a test block bypass or not. This is a mixed use commercial building. The first and second floors are retail spaces and the third floor consist of (4) apartment units. I will just be adding a 100amp meter main to the right of the last panel in the picture.
I could not find a reference in the code to a "test block bypass". Is that a code requirement or a utility provider requirement ?
Any input would be greatly appreciated.
That requirement is usually a utility need. They can close the bypass and pull the meter without an outage to the customer.
There's two flavors of bypasses 'round here.
A 'horn' bypass, which is just tabs added to the terminals of the meter socket that the utility crews attach short jumper leads to.
And there's a 'lever' bypass, a factory-installed mechanical method that does the same thing by moving the handle.
