friebel
- Pennsville, N.J.
I am an instructor at Delaware Technical & Community College, teaching three subjects to electricians from the residential, commercial and industry areas.
At present I am teaching three subjects, and they are,(1)Allen-Bradley SLC500 PLC's, (2)HVAC/R Electrical Control Circuits, and (3)NEC for electricians taking the exam for their Masters, etc.
The very important Safety message that I want to pass on to all electricians out there is, PLEASE USE YOUR ELECTRICAL TESTER to determine lack of potential when working on any circuit, and lock out.
I have been told of several incidents where my experienced electrical students have found switches where the Line side voltage has been put on the Load side terminals.
I know that you realize that your fuses will remain hot with this situation.
We know one reason that this was done. The apprentice electrician had cut the Line-side wiring to short, and they would not reach the Line-side terminals, but they would reach the Load side terminals. The apprentice electrician did not want to tell his boss the mistake that he made. Thank goodness that an electrician that had to work on that circuit, use his voltage tester, and he discovered the load-side terminals still energized when he open the disconnect switch.
It really troubles me when I hear of problems like this, but the bottom line is this: ALWAYS USE YOUR VOLTAGE TESTER TO MAKE SURE THAT THE CIRCUIT IS DE-ENERGIZED.
