Unless there is a specific reason to test the ground like a spec or otherwise being paid to do so, it is much easier to drive two rods and call it done for the day.
The AEMC meter in which you refer is what I call a BALL PARK meter. In other words it will always read higher than the actual impedance @ the test frequency of 160 Hz it uses. So if your spec say 5-ohms, and the meter reads 5-ohm's, assuming you know how to use it, the actual impedence is something less than 5-ohms.
