erickench
- Brooklyn, NY
Look at this question and the answer as given by the answer key.
A panelboard has four bus-bars and a nameplate with the information 3-phase, 4-wire A.C. 208/120V. If a lamp test set is to be used to determine which of the bus-bars is the neutral, you should for safety reasons, use
A. one 120-volt lamp
B. two 120-volt lamp
C. one 120-volt, 300-watt lamp
D. two 120-volt lamps connected in series
The answer as given by the answer key is 'D' two 120-volt lamps connected in series. I assume that this so because you may have to test across two phases at 208 volts and a single 120 volt lamp would not be able withstand that.
