1 = If the function/range switch is set at 200 VAC, what will the multimeter read if a measurement is made directly across both terminal of a good fuse or circuit breaker in a 120 VAC line ?
Would it be =(0 VAC) = (120 VAC ) (200 VAC)
2 = If the function/range switch is set at 200 VAC, what will the multimeter read if a measurement is made directly across both terminal of a Blown fuse or tripped circuit breaker in a 120 VAC line
