Re: tester for loose neutral
If you mean meter, all you need is a voltmeter, but, if you are in there anyway, why not just check the connections with the appropriate tool, and tighten any that are loose.
It should be done periodically anyway, especially in the first few years after installation.
If you are not a qualified electrician, I would suggest that you hire one.
Ed
[ May 09, 2003, 06:30 PM: Message edited by: Ed MacLaren ]
