If I have said this once, I have said it..............
The fact is flicker occurs, sensitivity has a lot to do with the amount of VD one can withstand (light wise that is).
Did a job with light flicker yesterday, I have attached the disturbances as well as a text print out of the voltage and current levels.
This house had an unusual number of incadescent light firtures 150+, and 7 HVAC units. This house had a 200 amp service that was upgraded to 600 amp, appears the utility left the 200 amp triplex in use, about 150" changed to 250 AL undereground 150, plus what appears tro be a 30 KVA pole mounted transformer (300 feet away).
Flicker is not just load, conductor lenght or transformer sizing dependent, it is also end user sensitivite. I have flicker but never really notice it, unless the wife says something. I have been to customers houses where it PLAIN WAS DRIVING the homeowner crazy and max VD recorded was 3 VAC. Others are just worried they have connection issues (a legimate concern).
NAME EDITED TO PROTECT THE INNOCENT
this is just shy of 3 VAC drop, I barely noticed it the homeowner was LIVID, and ready to sue.
__________________
Brian Gaquin
Sterling, VA (Washington DC Metro)
