electricalperson
- massachusetts
what would be a good method for testing if a battery is bad or not holding a charge?
Hey I got an idea. Charge it - if it doesn't hold the charge throw it away.![]()
I assumed you have another battery to eliminate a charger problem.
What type of battery are you asking about?
Load testing isn't the only way to check a battery's SOH or SOC. Conductance type testers have been around for years and you don't have to discharge the battery to test it either using this technology. Poke around at Midtronic's site, they've been in the battery testing business for twenty years.
ELA:Thanks Wptski - that was very interesting. I included a charger as part of the design of a piece of equipment a while back. It included a dummy load for testing the batteries.
I never liked having to dissipate so much power to perform the test.
If I should do anther I would definitely look into the conductance testing method.
Yes they have been around for years and were developed for SLA and VRLA batteries where there is no way to measure specific gravity and internal temp, nor will they tell you much about the capacity. There biggest drawback is unless you have a baseline measurement when the batteries were new and after the forming charge, the readings don't tell you a whole lot because you have no reference to measure against.Load testing isn't the only way to check a battery's SOH or SOC. Conductance type testers have been around for years and you don't have to discharge the battery to test it either using this technology.
