avalonelectric
New member
- Palm springs
How do you test fo ampere on a bus bar, when you have 120/208 volt switch gear, and the meter socket are rated to 100 amp and the service company tells you to install a 200 amp main breacker ..... by the way the switch gear it's a Rayco, I dont think I can find a 2 pole 200 amp able to feed an existing sub panel............ Thanx Alex
