Can anyone recommend a testing method for identifying poorly installed MC connectors on an array?
Frequently when inspecting large and small scale systems I run into issues where the installers have done a poor job of seating the pins correctly in the connectors or where a connector has been arcing internally for one reason or another but no ground fault has yet presented. With the newer inverters all having AFCI equipment in them this issue has become more and more a hot ticket item in my part of the industry. I am trying to figure out a reliable testing methodology for identifying these issues before thermal failures occur. I was thinking that one possibility might be to do a resistance test through the strings and do a comparative analysis. In theory a poorly seated MC connector pin terminal or one that has been arcing internally should manifest as a abnormally high resistance through the string when compared to a known good string. Howveer, it occurs to me that this test is a bit dangerous (requires shorting of the string through a resistance meter) and may be unreliable.
Can anyone confirm if this is a good approach or suggest an alternative route to consider? I'd like to be able to test for this condition before a thermal failure and ground fault manifests. Any advice you can provide would be greatly appreciated.
