Can someone tell me where the fault is, I think I know but I don’t like shoveling dirt!
Had a service call today, a boat lift on a pier was not working, (this lift has been working for years prior with no issues), the lift is 120 volt 30 amp breaker, when I tried the up switch the contractor just hummed, checked the voltage at the lift under load it dropped to 93 volts. Went to the beginning of the pier at the sub panel, the breaker voltage was 93 volts under load. Checked the pier panel main, the voltage again dropped to 93 volts. Went to the house service pier panel breaker, there was no voltage drop at the breaker under load. The size of the wire is fine. Can I assume there’s a fault in the wire from the house panel to the pier panel because of the voltage readings? (FYI , I ran my own temporary power to the lift and the lift worked fine).
