I ran into a problem while testing a GFCI in a customer's kitchen. The circuit is apparently split in a junction box, which I have not yet found in the basement dropped ceiling. There is a GFCI beside the sink, and its load side feeds a switched lead to the garbage disposal. The township inspector tested the sink GFCI using his external tester and the GFCI failed to interrupt. The test button on the GFCI works correctly to interrupt the receptacle. When I tried my external tester, it indicated correct wiring of the GFCI, but when I pressed the test button on the external tester, the outboard light dimmed and the GFCI did not trip. I replaced the GFCI with no change in behavior. I disconnected the disposal wires from the GFCI load terminals, with no change in behavior.
There is another GFCI on the same circuit, across the room, apparently separately fed from the junction box. The GFCI across the room tests OK using either the GFCI test button or the external tester.
Based on discussion in a related thread (GFI Receptacles), I suspect an open ground connection between the junction box and the misbehaving GFCI, but that should have been indicated as an open ground on my external tester.
Any ideas?
Any ideas?
