just stumbled upon this "glowing wire nut thread" that is closed:
http://forums.mikeholt.com/showthread.php?t=142595&page=13&highlight=glowing+wire+nut
2 questions I have. The first, there has to be some way to do continuity tests to locate loose connections? Possibly even a wired circuit. How about turning of the breaker, could make some receptacle jumpers using a plug end, flourescent lights could be tricky, but then check the continuity from the breaker load side to the neutral. This would be for a simple residential circuit. Any thoughts on this?
Next, in the thread, somebody keeps referring to lineman pliers. Are they saying twist the wires then twist the wire nut or use pliers to twist the wire nut? Always thought the wires go into the wire nut straight then twist the nut only. The wire nuts with a hex head are great for this purpose, and remember stranded wire always sticks above the solid wire. Also, putting electrical tape over the connection is a good idea.
