dmanda24
I had a service call where the GC had cut the wall for a new door and there were 4 MC cables that needed to be re routed, how would you trace this MC cables, the Non- contact fluke voltage stick does not work on the outside of the mc cable, so there was no way to check if you had found the right circuit by turning off breakers, since the wires had to be cut to be re routed I ended up using an MC cutter to expose the wires and test that way. how would you do it if you didn't want to cut the cables. Is there a particular tester good for this?
Thanks
Thanks
