Stevenfyeager
- United States, Indiana
- electrical contractor
Can I test voltage drop when no load is on the circuit? I have a 20 amp 120 volt circuit from a utility pole on a 120 ft 10-2 UF then continuing on with a 100 ft #12 extension cord for a new house construction. I tested that 220 ft length with my volt meter and showed no voltage drop compared to the utility pole. What will happen when the framers start using their compressor, etc? Thank you
