s.cabbie@netzero.net
- Montana
ok so here it is.. t= temperature, w= waterproof, e=?. this is a factory setup, only problem is that the line current through this wire is 26.6A, an it is fused @ 30A time-delay class g fuses. everything in this equipment is heat-stressed. It doesn't make sense to me, but factory stuff is exempt seems like a lot of the time from the codes I follow at work. So what is the allowable ampacity of this wire for real?
