joe tedesco
- Boston, Massachusetts
joe tedesco said:
I didn't see any of the units complete immersed in the water. I believe that that immersion detection device is in the handle that was never under the water.This type of immersion would certainly be protected against with an IDCI.
stickboy1375 said:You still didn't answer my question, why should a gfci trip with an appliance submerged in water?
Were the other examples in that same sink? If the other examples were not in the same sink, then you cannot compare them. Some installations may have a ground fault path while others many not.I have other examples were the appliance did in fact trip the ALCI, and GFCI so the possibility that the path was there, or the device was faulty in the video clips are likley.
joe tedesco said:The comments here by others helped to answer the question, and I agree.
I asked for comments, and was looking for some replies.
Will you share yours, or give the reason why you feel the device did not work?
Most of these types of appliances make it very clear that they are to be kept away, as shown in the image here:
stickboy1375 said:At least stick your hand in the sink first...
cowboyjwc said:Well I couldn't get the video to play so I'm not sure what the discussion is all about, but Stickboy, I'm pretty sure that Joe knows how a GFCI works.
