Sizzler
New member
- Bayport, NY, Suffolk county
OK first let me start off by saying this is a great forum,and have been a reader for a while, and would like to thank all involved. Withthat being said let me explain as best I can what I am asking. I have a buildingwith a 1600 amp 480/277 service. Currently using about half of the availablepower. The building originally usedbarely any 120v equipment so only had a 75KVA either 208/120 or 240/120(Iforget its been awhile since been there) transformer which is now running about70-75% on all 3 legs, so taking anymore 120/240 off it is not an option. Have plenty480/277. Customer wants to add 2 tanning booths that ask for 60A 208/240 singlephase, in specs. they really only run at 45amps, so I am still going to use fornow 60A, so not to figure a load factor. Now what is best and cheapest way todo this. Customer states will not being adding anything else, so I need only enoughKVA trans to run the two units ( I was thinking about same labor to installanother 75kva step down with 225 amp panel to give room for future, he statesdon?t need anymore for future, I guess its going to come down to cost onthat) . So I am thinking installing one35-45KVA 3 phase to panel with one unit on AB phase and second on BC phaseleaving some room on AC phase, or maybe (2) single phase 480/277 to 120/240transformers would probably be around 12-14kva (if they make single phase480/277 units?) What are your thoughts on best/fastest/cheapest way. Thanks
Don
(if I left anything out which probably did, just let meknow)
Don
