- Lockport, IL
- Semi-Retired Electrical Engineer
Re: The Chicken Switch
How about keeping it simple, like "remote operator"?
A related question. If you are in the room, within the arc flash boundry, but not operating any devices, or working on the equipment, is arc flash protection required? I think that it is, but am not sure. Does the arc flash boundry change when the covers or doors are open?That is 15kV switchgear and the arc flash boundary is probally around 20-25 ft, there absoutly is an arc flash hazard and the 70E requires a flash suit to be worn for this operation.
Yes, arc flash protection is still required but the probabillity of one occuring when you are not doing any operations is slim to none.If you are in the room, within the arc flash boundry, but not operating any devices, or working on the equipment, is arc flash protection required? I think that it is, but am not sure. Does the arc flash boundry change when the covers or doors are open?
This requirement already is in the 2004 standard.It is very likely that there will be no energized work on any system with an incident energy that exceeds 40 cal/cm^2.
