I know the NEC definition of these: Grounded conductor, EGC (Equipment grounding conductor) and GEC (grounding electrode conductor) and they are determined based on NEC Table 250.102(C)(1), Table 250.122 and Table 250.66, respectively. However, I am uncertain as to whether they are all required for my application. For instance, I know that when you have parallel runs then the ground wire is not required (what NEC Code is this?) but not certain with clarity what is needed. For instance, the service disconnect what ground is need (NEC code?), for the transformer secondary cable (4 #300kcmill) does one of the conductors act like a ground (NEC code?). Also a schematic drawing example would help, cause I have read a lot of explanations but nothing that really shows all these three grounds at a time pictorially.
