Re: The Two Legged Wye:
Bob,
 Thanks for your response, but I must nitpick:
 You have implied a 1:1 turns ratio, then the secondary and primary phase currents would be Iline/sqrt(3).
 (OK, I see you fixed it)
 However, the factor is still 0.577, the inverse of sqrt(3).  It appears that this factor does apply to the two-legged wye and provides the allowable connected load as claimed by Jim D. previously.  His numbers had demonstrated that already.
 Now if we connect two single phase loads directly across the two secondaries, the ratio becomes 0.667 because we now have 240V instead of 208V driving the loads.
 In either case though, the apparent power computed at the transformers must be the same, and it is.  Whether you add these apparent powers or not is immaterial.
 And what is the ratio of the two ratios?
 0.667/0.577 = 1.15, the O.F.F.
 It is apparent to me that the O.F.F. is just a different approach to the problem of transformer loading.  It is just as valid as 57.7% or any other factor in use.  To say it has no basis is to bury one's head in the sand.  It may not be in wide use and may never be, but it is still valid.  At least give the Oregon guys credit for coming up with a killer trick question.
  [ March 23, 2005, 11:16 AM: Message edited by: rattus ]
