I have a problem. First, I'm out of my knowledge base. Second, I am working on thermocouples for a project and I am struggling to get my head wrapped around these... things.
Here's what I have. Type T thermocouple. I am sure that's the type. Red negative, Blue positive, brown jacket, rolled off reel with label stating Type T thermocouple. I say all that because I am baffled by what's going on. I'm sure it is simply my lack of understanding, but ....
All I'm trying to do is use this to measure temperature. I will eventually incorporate a thermistor to monitor cold junction temp for compensation, but right now I'm only interested in the thermocouple. Oddly enough, I have the thermistor circuit working flawlessly for monitoring ambient.
Now the real issue. All I am doing at the moment is measuring the tc cold junction with a Keithley 2001 DMM. Per the data sheet for the Type T tc, I should be reading approximately 0.911mv as the ambient temp is about 73°F or about 23°C. Here's the rub. The DMM is measuring -0.035mv. The DMM is calibrated by our lab and has been checked and verified to be working properly. I have tried 3 different sets of tc's to make sure it wasn't a fluke. All 3 measured similarly.
What am I doing wrong? Again, I presume it is just my lack of understanding, but I don't know what else to do to use these tc's to measure temperature. My plan was to simply connect them to my 24-bit sd a/d converter, add the thermistor cold junction voltage and wham-bam temperature. But what I'm measuring at the moment is just plain wrong somehow. Can someone give me a hint, push or whack up side the head?
