bark
- Washington
Good afternoon,
I was wondering if you could help me here on a puzzling theory question? My son's company, not electrical, dirt contractor has a portable light standard that runs off a generator. There are 4-1000 watt metal halide lamps. Each has it's own ballast and capacitor. He asked me this morning if I could take a look at it because of a problem they were having. It has four separate switches that turn on the lights individually. Now the question. I would turn # 1 switch on and fine, it worked, turned #2 switch on and fine, it worked, then turned # 3 switch and it worked, then I turned # 4 switch on and that in turn turned off # 2 and #4 would not work. The same happened if I turned #4 on and then turned #2 on, both light would not work. I did find a that the cable leading from the switches was pinched at the knuckle where the light stand could be cranked upright. There were 4 smashed wires along with the neutral wire that was also damaged. There was also a grounding conductor in the cable but didn't notice any damage. I've been trying to think of the theory that involves this but can't seem to come up with an answer. There were no tripped breakers/switches. Thanks if you can help my curiosity.
P.S. I have been a journeyman wireman for 35 plus years with a masters license so hope you understand why this puzzles me.
