Although we hire this service out on projects that call for it, we bought a Milwaukee thermal imager ($2,200) for our own use as an electrical contractor. We sometimes get into service work or troubleshooting where a quick scan with a thermal imager would save us a lot of time to identify hot spots.
My question is, what temperature range is acceptable for lugs and wires in a panel, transformer, etc.? I would assume since the rating of lugs or wire could be 75 or 90 degrees that anything above this temperature needs attention. Am I off base here? I know there is a lot more to it and there are extensive training programs for thermal imaging that cover what the data collected actually means. But since we are not interested in providing this service or using it too often (only for our own projects), is there a reference guide or cheat sheet we could use just to help us know acceptable and unacceptable temperature ranges for certain things?
For instance, I just checked a panel and found a 3-pole breaker that is 101 degrees while the rest are around 80 degrees. I assume that this is a concern and could be a loose connection.
Thanks in advance for any help.
