tylerjbrooks
Hi everyone. I am new to the forums and would greatly appreciate some help/advice with a problem.
I am engineer and I have been given the problem of designing an audio amplifier and power supply that I can install in the walls and ceilings of a home. I was wondering if anybody could advise me about heat dissipation in walls and ceilings. Does the NEC address this issue?
I am looking to design an audio amplifier and power supply that is powered off the main house power lines. It will be in the 100W range (50W per speaker) but that depends on how efficient the device can be made and the thermal limits of common walls and ceilings.
I assume that the device will have to be installed in uninsulated locations of walls and ceilings. I also assume it will be attached to a stud. Furthermore, the device doesn't have to be 'pretty' so I will probably make its case a heat sink (aluminium case with fins).
I want all heat transfer to be passive. No fans.
The device itself can survive up to 125C. I know that drywall will withstand about 100C and I also know that a good upper ambient temperature in a house is about 50C. So, is it ok to design a heat tranfer that keeps the device below 100C when a house is at 50C ?? Or is there a set upper limit?
One more thing...
Please excuse my ignorance of the code, but does the code require that I place this device in a 'can' or metal box? Does it have to be vented in any case no matter what the heat transfer is? I know that halogen light power supplies can get pretty hot. Where can I find the rules about about their installation?
Thank you in advance
Tyler.
One more thing...
Tyler.
