I am a second-year apprentice, working on an NEC problem where I have an electric heater protected by 60-amp fuses with a control circuit with a thermostat, also protected by the same 60-amp fuses. I'm trying to find out what size the control circuit conductor should be. I'm using THWN Class 1 control circuit wire protected only by the 60-amp heater fuses. I come up with #4 wire, as do many of my classmates, but my instructor says that is incorrect and that it should be smaller, but he couldn't recall the code reference that allows us to de-rate this conductor. Do you know of any code reference that could help me with this problem?
