e150club said:if the therm. can handle the load why install a contactor.
You've answered your own question: if the T-stat is rated for the voltage and current both, there's no reason against it, as long as you can terminate your connections properly.e150club said:. . . it depends on the load of the motor and the rating of the therm. if the therm. can handle the load why install a contactor.
e150club said:fractional hp less then 1amp
Pierre C Belarge said:Are you stating this does or does not require a Chapter 3 wiring method?
What is the voltage?
