Thevenin Theorem
Student323
ThinkingNotToThink
Chi Town
Engineering Student
Hi All,
I am studying for my FE Exam and I stumbled upon a concept that is very confusing.
Sometime some example tell me to ignore the resistors facing the short circuited voltage source, other times it seems like i do not need to.
For example, this problem here does not ignore the 6ohm resistor after the voltage source is shorted
whereas for this example, the 6ohm is ignored. The only conclusion i can think of is when the resistor is in parallel with a shorted voltage source, it can be ignored.
Any insight will be greatly appreciated
The equivalent of two parallel resistors is their product divided by their sum. A short circuit in parallel with a 6 ohm resistor is equivalent to (0 × 16) / (0 + 16), or zero ohms. That is why you can ignore the 6 ohm resistor in the second question.
