THHN is rated for 90 degree C and THWN is rated for 75 degree C but both of these ratings can be listed on the same wire. Just want to make sure I have this right, if installed indoors you can use the 90 degree column for ampacity adjustment but if installed outdoors you must use the 75 degree column?
