wirenut520
can you run thhn with 24 volts in open air with cat 5 cable
.....The "W" is for weather!......
Not the same, necessarily, but at least as high as that which the higher voltage present requires.If for example the two different voltage start out in the same conduit the insulation valve has to have the same insulation value, if met the voltages would not be a concern.
