Shockedby277v
- Michigan
I have to run my power inside steel columns. I'm not sure the thickness but if I had to guess I would say it's about 3/8" thick. Anyone know any good methods? I can go as big as 1 1/4" before the column starts losing strength. I may try to torch it then grind it or use a drill with a drill bit or hole saw. I have made holes with hole saws through steel before and it is a slow process with a lot of hole saws ruined. I'm thinking of running MC to keep the holes small. There has to be some good methods.
