raberding
- Dayton, OH
- Consulting Engineer
Yeah its just the terminals, I'd look around for the rest of the system see if its still there, probably long gone.If it's part of a 1A, where's the KSU (relay box). Could be terminals for a key system, but it's still just the terminals.
1A2 could support hundreds of stations and hundreds of lines. But when you need that capacity you go to a PBX instead.1A2 systems used 25 pairs for up to 8 instruments, 3 pairs per device.
Isn't that a motorcycle?But when you need that capacity you go to a PBX instead.
My first full-time employer* had a 1A2 system with somewhere north of 300 automatic-ringing private lines, spread over 4(!!) 90-button Call Directors and a bunch of 18 and 30 button Call Directors. (The 90 was three 30's in one chassis.) Those sets wired to concentrater KTUs to mux the control lines. One of the projects while I was there was building a replacement switch for the whole 1A2 system; off-the-shelf systems were far to expensive for what we needed.1A2 could support hundreds of stations and hundreds of lines
Were you successful? What did you use?One of the projects while I was there was building a replacement switch for the whole 1A2 system
Yeah, that was the time where if you blinked they had something new. The Merlin, the first all electronic key system was being installed by AT&T to replace the 1A2. Instead of running 25pr (and multiples of) all over, all it used was 4pr. Thus was borne the RJ-45 and the 568A WECO standard.And as time went on and telephone tech improved, those private lines started to be replaced anyway.
Still have a few left. The old Merlin is pretty much extinct but if you wanted to be historically correct you would want to use those original gray line cords. Whenever I saw a patch cord being used I would know some computer guy or DIY was playing with it.the wall-to-set cables supplied later looked like Ethernet patch cables but were 8c in a jacket, no twisting/etc; needless to say, they did not work like an Ethernet cable
