Please bear with me, We came across a interesting thing today.
We were finishing up some loose ends on a house remodel. The service was upgraded - new weatherhead, riser, outdoor meter can, service entrance into the new 150 amp Sq D panel. New ground rod, and wire, new bonding wire to the street side of water meter. The house has a copper water main from the street, and plastic lines through out. Upon taking off the the wire from the water pipe clamp (so it could be rerouted), there was a big blue arc.
It acted like the was a open neutral. Upon reading across it we were getting 50 - 60 volts between the water pipe and the bonding wire. You would think that with the neutral and the bonding screw in the panel along with the ground rod all connected, we would not be getting any voltage on that wire. We found out that the lights in the basement would dim when the wire was removed. After checking and tracing all that circuit, and made sure the neutral was connected all the way through, we had that same results..
It is impossible to describe everything we tested and checked, however 2 electricians 1 with 20 yrs in trade and one with 26 yrs in trade we are totally baffled.. I will keep checking this and updating as suggestions are made, if it something we has already checked for.
I want to thank you all in advance for you help...
Roger
Roger
