This is your brain on power
Coppersmith
Tampa, FL, USA
Electrical Contractor
I saw this quote from National Geographic's "Your Brain" on CBS Sunday Morning:
"Your brain uses 20 watts of power..."
Now I'm curious about the voltage and amperage. I don't have enough info to do an Ohm's Law calculation.
drcampbell
The Motor City, Michigan USA
Registered Professional Engineer
JFletcher
Williamsburg, VA
I remember reading somewhere before the human body generates about a hundred watts per hour. I also remember going to York Power Station as a kid and riding the bike they had hooked to a little Dynamo. you could just about power a hundred watt bulb peddling as fast as possible. then they said that at that rate you would have to pedal for something like 3.6 days to generate the amount of energy contained in a gallon of gas or maybe it was a pound of coal
Ingenieur
Earth
Wikipedia says that each neuron fires on less than 100 mV. No mention of current, but if billions & billions of neurons collectively require only 20 W, it's not much.
https://en.wikipedia.org/wiki/Neuron
Popular Science says that 2 milliamps to the scalp doubles your brain performance but, like every licensed electrician I've encountered, doesn't recommend doing it yourself.
https://www.popsci.com/technology/a...in-improves-video-game-skills-researcher-says
20 w = 0.1 v x i A so i = 200 A
if we assume 1 mil neuron firing at any given instant
200/10e6 = 2 uA per neuron
what is the avg power at a given point from all emf? voltage gradient?
radio, cell, tv, power lines, etc
edit: The human brain has about 100 billion of them. Each neurons fires (on average) about 200 times per second. And each neuron connects to about 1,000 other neurons.
much smaller i
200e6 firings per uSec
Have you guys forgot your thermo? One Watt is one Joule per second. It is a unit that can be used to express all energy, heat, mechanical, chemical, and electrical. Watts law would not apply. Unless you were all joking, in which case I am just bieng that internet guy who cant recognise sarcasam.
Sent from my SM-N910P using Tapatalk
Ingenieur
Earth
what???
W = J/s or dE/dt, ie the rate of energy transfer
as in across the neuron/synapse
20 W = 20 J/s
100e9 neurons firing 200 / sec at 100 mV / neuron or junction
you have everything you need
what???
energy can have more forms than electrical. A Watt can express them. for instance I can heat a space with gas and express the energy added to the system in watts. I can also lift a brick with my hand and express the added potential energy in watts.
Ingenieur
Earth
you are stating the obvious
chemical, thermal, nuclear et al
the point is you said P= v x i does not apply
if we assume the 20 W to be electrical (since this is an electrical forum and the post wss more or less tongue in cheek) it does apply
it was a smug insult against all forum members
like you are smarter
lighten up
I see, I did not assume that the power was even partialy electrical. Ok I guess I am bieng that guy.
Coppersmith
Tampa, FL, USA
"Now it appears zapping your brain with a 9-volt battery will make you better at video games, at least according to one researcher."
Wow. This might be the edge I need to beat all those 10 and 12 year olds who kick my behind at Overwatch.
Coppersmith
Tampa, FL, USA
lighten up
Actually Ultrafault, I was not offended and thought you made a good point. I had assumed the energy is electrical, but it could be chemical energy they are talking about in the National Geo article. I didn't read it. It's probably not nuclear unless you have developed super powers from being in an industrial accident.
roger
Fl
Retired Electrician
My outboard engine is rated in KW and HP.
Roger
