daveselectric
- Ohio
I ma replacing the panels in a three family home. There are three meters.
The 1st floor suite has 1134 sq ft, the 2nd floor has 1008 sq ft and the 3rd floor has 246 sq ft. Each suite is fed with 100 amps. We installed a triple overhead meter base. The permit states "special notes and comments, Per 2011 NEC. With attention to Table 310.15(B)(7) sized for 300 amps." We used 4/0 aluminum for the rise abofe the meter base. In Ohio we are still using NEC 2011.
Is Table 310.15(B)(7) designed to cover the rise above the meter?
