powerplay
- In front of a computer.
I've come across some approved equipment that has been hooked up to 244 volt supply receptacle, which I believe is acceptable being close to within 10% of required voltage. A similiar piece of paper cutting equipment with the same three phase 220 volt requirement is going to be twist locked into the same outlet when required. I am planning to connect the equipment to 12/4 soow cable, with an Three phase 250volt 20 amp twist lock plug to allow them to run the equipment. I would like to hear if there is any feedback regarding this installation. Could there be issues with this equipment when running this way? The equipment has built in overloads and controls.
