Barbqranch
- Arcata, CA
- Plant maintenance electrician Semi-retired
I mostly deal w/ single phase 120/208 power (or is it 208/120, I can never keep them straight) in a small industrial setting. Another warehouse facility has a high leg delta service.
Ok, so here is the question. If I wanted to look at the 208 three phase w/ a 3 input scope, I would just measure all the wave forms from neutral, and the three sine waves would be separated by 120 degrees. No problem. However, I am having trouble picturing in my mind what the scope pattern would be for the high leg delta, and what would be the logical place to measure from (I am guessing neutral). And what the phase angles would be from that perspective.
Thanks.
Thanks.
