hmspe
- Temple, TX
- PE
I'm working on a relatively small commercial building that was designed at 208/3. A Thyssenkrupp 25HP elevator (Endura 21 A with integral solid state starting) has already been installed. The elevator documentation specifies 208/3 but does not have a voltage tolerance stated.
2+ years into construction the building does not have utility power connected, and the utility's rules have changed and they now cannot serve the building with 3 phase because of right-of-way issues. All that is available is 120/240/1 at 800 amps max. I expect that this will be on a transformer shared with other shops. Changing to a single phase elevator is not an option.
I'm looking for suggestions on the best type/make/model of phase converter for this application. I'd like to use a static converter, but I can't find any literature on using a static converter to supply a device with a solid state starter. If the converter needs to be rotary are there any things to look out for?
Thanks.
Thanks.
